iPhone's RAM
Jan 10, 2007
22
Does anyone know how much RAM the iPhone has? eg. 512MB, 1GB?
maybe you can't have multiple applications open at once because there is only a bit of RAM.
ColsTiger
Mar 8, 2007
5,856
Columbus, GA
From what I've read it has 128MB of RAM of which 11MB is for integrated graphics.
15,385
1,089
i thought there wasn't a consensus on this topic yet... in any case, it's not readily provided by Apple for whatever reason.
What? I have several apps running together all the time.
- John
kdarling
Jun 20, 2007
425
NJ, NC, CO
It's one of the reasons.
By keeping the number of loaded and running apps to a minimum, Apple is hoping to avoid getting into a tight memory situation.
It's an easy solution for the OS writers. Not so much for developers, who might need to handle saving their state and reloading it the next time you click their icon and the app is reloaded into RAM from flash.
Not the best for battery life either, since extra cycles are used for saving, then reloading / restoring data.
All that said, 128MB is a fair amount. Most handhelds, with only 64MB, do run into tight memory. Those with 128MB are much better off.
drumthrasher109
Jan 9, 2009
471
drumsplace.co.cc
How much RAM does the iPhone 3G have? I noticed that right when I get on to my iPhone after I restart it, there's 25MB available (according to SBsettings).
patrickj
Sep 2, 2007
6,221
445
Austin, Tx
ipadinsight.com
True - 256 would be sweet. This is pretty much how nearly all smartphones are - OS and system processes chew up a lot of memory right from the off ...
