iPhysics level packs fix?
MundoGrande
Jan 26, 2008
155
Hey guys. I've asked, and I searched and still can't find an answer. I've downloaded a bunch of level packs, but they aren't showing up in iPhysics. Yeah, I even downloaded 666's fix. Still really lost and would love an answer.
So far, I've tried:
Uninstalling and reinstalling
uninstalling, downloading the fix, installing
installing, downloading fix
I'm lost. :(
x999x
Aug 6, 2007
1,656
So far, I've tried:
I'm lost. :(
Hi, I've adjusted my fix to check for the BSD Subsystem first before it tries to do anything. If you don't have it installed it will let you know.
BSD Subsystem is used by a lot of applications, and by my Installer source to change permissions. If you're not having any luck running my Fix, please check that you've got BSD Subsystem installed, its in the System category in installer.
