iPod Classic won't hold a charge
Bullgod
Oct 15, 2012
My iPod just makes a clicking sound and the screen flashes when I connect it to either a charger or to iTunes on my PC. I'm assuming the battery is pooched. Can the battery be replaced or no?
28,365
5,507
1. Does it accept a charge?
2. Does iTunes recognize it?
3. Does it work when it's not plugged in?
I'd take it to Apple for a diagnostic and quote for a repair. It might be the hard drive. The battery and hard drive tutorials on iFixit are both listed as very difficult.
Bullgod
Oct 15, 2012
No to all. All it will do is click and flash.
Mrallank59
Jan 8, 2013
250
31
Europa. Do you know which iPod this is? I've had it for 6 or 7 years, now. I think it's called the classic, but I'm not sure. It's 160 GB
Mrallank59
Jan 8, 2013
250
31
The reason I wasn't sure is, I saw a clear case for the Classic, at the Apple store. It wouldn't fit properly. So, I'm wondering, is there different classics?
