iPod function closes
zingaro
May 12, 2008
I have transfered playlists from my iTunes (manage music manually ...) to a friends newly bought 16gb, 1.1.4 iPhone. the transfer worked fine but when I launch the ipod function on the iPhone it will open and close immediately. I deleted all music and used the wipe ipod function from the Boss Prefs. and copied again and ended up with the same problem. Any idea how to solve the problem? thanks
Youngbinks
Jun 4, 2007
7,617
31
Atlanta, Georgia
That's really odd and I don't think I've seen the problem before. However, try converting all songs that you're trying to sync to AAC format. I know that when a particular song won't play that usually fixes it so hopefully it will work for your problem as well.
I've heard that manually managing music cause problems. Try syncing without that option and see if that fixes it.
- John
