iPod function is misbehaving
Flyingstar
Jul 29, 2007
343
So. Cal
It used to play all the content of an album or artist. Now it repeats the same song instead of segwaying to the next? I have looked everywhere trying to find a setting that is wrong..no luck. even if I choose shuffle it still plays the same song over and over. What happened?
Flyingstar
Jul 29, 2007
343
So. Cal
Sure could use some HELP! (I just did a restore and it did not help)
iphonewarrior
13,847
701
Do you have your songs on repeat? Tap the Album artwork and you'll see a circle (more oval) with two arrows going round. Does it have a small number 1 on it? If it does, tap it again, then it will play the next tune on completion...
Flyingstar
Jul 29, 2007
343
So. Cal
THANK YOU!
Flyingstar
Jul 29, 2007
343
So. Cal
There used to be a smal icon on the topleft that you could highlight (or not) to repeat an album. It is gone! and all my albums are now repeating?
Kadelic
Jan 4, 2010
4,940
1,646
Dallas, TX
Try tapping on the screen, it should bring up that icon again. If not, try rebooting or doing a hard reset.
