iPod nano 7 & iPod classic on one PC
KeziaPurrs
Mar 18, 2013
86
22
Houston, TX
I'm purchasing an iPod Nano 7 for working out with. I already have an iPod Classic which I sync with my PC. I have about 100 GB of music. If I connect my new Nano to my PC will it try to sync with my Classic's music? I want to create a special playlist primarily for the Nano. Can I do this, or should I load the Nano using another app?
Thanks soo much for your response(s).
Lisa
Sent from iPad Mini-Me using iCafe app
IllusionEntity
Jun 3, 2010
1,987
163
Borough Green, Kent, UK
When you plug the nano in you will be able to specify which music you want it to sync under the music tab in the device window in iTunes. And yes you will be able to creat playlists especially for the nano too.
KeziaPurrs
Mar 18, 2013
86
22
Houston, TX
Thanks so much! I look forward to receiving my Nano in the mail tomorrow!
