iPod on iPhone Issues
Jun 19, 2007
33,493
4,551
Upper Marlboro, MD
The iPod on my iPhone is always on repeat mode. How can I turn it off? Can someone help? Thanks.
There's a small "loop" icon next to the progress bar when playing a tune. If it's set to loop, the icon is blue and will have a tiny number "1" on it. Just tap the icon until the number "1" disappears and you should be good to go.
FAsnakes
Jul 10, 2007
ok try this...
Click on iPod, select a song (stay out of coverflow) as it plays click on the middle of the screen. On the left of the progress bar you'll see two arrows going in a circle. Click it until it's white.
If that don't work, reboot the phone and try again.
Reclean the surface & try again.
Make sure you're running the latest version of software from Apple, 1.01.
If all that fails you can try a restore.
And if all that fails after all that, you probably want to call Apple.
Good Luck,
