iPod songs & iTunes to iPhone
Clogan
Dec 11, 2011
I have an iPod touch and set up and iTunes w/ my laptop and now I have an iPhone 4 and I want to put all my songs from my iTunes on the laptop to my iPhone. Can this be done and if so, how? Thanks for helping!
rambo47
Apr 4, 2010
528
79
Northern NJ
You should be able to simply sync your iTunes on the laptop to the iPhone and have the exact same music on both your iPod and iPhone. A regular sync via the USB cable should get it done.
Clogan
Dec 11, 2011
I tried that. I plugged in my phone just like I would my iPod and nothing happened. It didn't even have that thing on the left that's says "cortneys iPod" when I plug my iPod .... I'll try again tho. Thanks for responding!
RoofMonkey
Jun 21, 2010
8,921
1,983
We're the songs ever on your computer to start with? If they are you may have to import them to a new playlist for the iPhone.
If they aren't, look for a program called SharePod for your pc. This will pull all of your music off the iPod and put it on the pc so you can then transfer them to your phone.
