iPod songs keep repeating
bad1550
Aug 13, 2007
27
When I select shuffle songs from the iPod, the song keeps repeating for some reason. This has never happened before in the 2 months with the iPhone.
I would appreciate any help.
Thanks,
Bob
iPhone69
Jul 13, 2007
128
South Florida
when you are in the iPod section, and the album art is showing, tap it once. You will seen a small screen appear from the top and in the left corner there is the loop setting that should be blue. Tap that once it will go back to white and your problem will be fixed
bad1550
Aug 13, 2007
27
Thanks!
Bob
