iPod sounds issues?
clausenfan
Aug 24, 2007
66
My speakers work for ringtones, but when i try to listen to music on ipod part through speakers it doesn't work. What could the problem be
Griffinaz
Oct 5, 2007
1,046
Phoenix, Arizona
I am not sure this is the same situation but there is a switch built into the headphone jack and there have been several posts here about people not hearing music through the speakers. To fix it they plug and remove their headphones a few times and then it will work. The other posts I searched for didn't mention that the ringtones still worked through the speaker so this might be a different problem but that is a super easy thing to try so I recommend you do that first.
