iPod Touch 4th Gen - slow response
dinosaur1
Nov 10, 2007
516
Lately my iPod has a slow response time when I turn it on and off and as I swipe from one screen to another. I hard booted, made sure there are no apps in the memory and cleaned out Safari's cache and history.
Any help is appreciated.
Mommy
Feb 19, 2011
1,104
88
NY
My iPod has been like that since 5.0. I called Apple on an unrelated matter and was told it should not do that... Still does it though... Tried the resets and redoing the software and all that stuff... Good luck, I have heard other people saying the same thing....
Smarty2600
Apr 23, 2011
344
11
Same problems, overall it doesn't bother me, I've had several iPod touches to know that with each generation of software I add to it, the higher the specs the better the software functions. And so my guess is because the 4th gen iPod touch is only a single core it's a bit laggy compared to how a brand new iPhone 4s might work.
kaser123
Feb 12, 2012
i have the same problem after i installed a number of apps and movies, i guess it has something to do this. Just get rid of unused apps and other documents, it will get a little better according to my personal experience.
peter.alex
Feb 16, 2012
Actually the problem is that ipod got slow down when we start installing applications and without apps, ipod has nothing to do with, atleast for me. So we have to make ourself used to of this laziness ;)
fury
Oct 23, 2007
2,274
236
34
Louisville, KY
I have both a 4th gen touch and iPhone 4 on iOS 5. I do not have any noticeable lag, at least not beyond what I get with a fresh 4S (App Store Purchases section is particularly bad in my case).
Are you noticing these symptoms system-wide, or particularly with certain apps? Maybe narrowing it down to Photos can reveal a corrupt photo, for example, or some app interacting badly in the background.
