iPod touch jailbreak
KyDuckman
Nov 29, 2007
41
My cousin just got a iPod Touch and has version 1.1.1 all she wants is for it to be jailbroken so she can add some apps like iPhysics and such.
Do I just need to go to jailbreakme.com and it will do it?
KyDuckman
Nov 29, 2007
41
Does anyone know if this is right or not?
Feb 1, 2008
yes...that is correct.
for a 1.1.1 that is all i did to jailbreak mine.
then use installer app to add sources and apps....
good luck...i know it's a few days old post but hope you either read it or were successful before now.
KyDuckman
Nov 29, 2007
41
Thanks, for getting back with me!
Oct 27, 2009
20
Miami
Hello everyone. I just bought an iPod touch from a friend and was wonder if it can be jailbroken. I JB my iPhone 3gS a while ago and was wondering if the iPod touch can do the same. Thanks
Jun 12, 2009
970
yes, is the same thing, just make sure that the ipod touch is running 3.1.2...
Jun 12, 2009
970
yes, it should work fine, but just remember, make sure its running 3.1.2, i jailbroke my brother's in law iPod touch with blackra1n running 3.1.2...
so as long as you have that firmware, you should be ok...
If you look in the iPod Touch Hacks section, you will find a stickied thread that will take you through the process of Jailbreaking your iPod Touch System. You can also click the link in my signature to get there.
