iPod USB Charger on iPhone
ravman
Oct 4, 2007
1,197
Mean Streets of LA.
Has anyone else tried using their iPod USB charger on their iPhone? When I use mine, it takes hours to charge my iPhone literally another 10%, that is it.
Seems like the iPhone and iPod require different amounts of charges, and you cannot swap chargers between the two units.
I won't be using my iPod charger anymore, in case it messes up the battery in my iPhone.
Hang on, if I mess my battery up, I can just buy another one from the Apple store and replace it right? Dang, I need to stop smelling gas fumes.
akophone
Aug 1, 2007
300
The iPhone charger is 5 volts.
Older iPod chargers (firewire) outputs 12 volts.
If in doubt, I would only use the charger that came with it or
Use your computer to charge it.
ravman
Oct 4, 2007
1,197
Mean Streets of LA.
The iPod charger I have is also 5.0v-400mA. I am also using the iPod USB cable, but this shouldn't make any difference.
I am going to plug the iPhone directly into my PC and charge via that.
I've ordered an original Apple charger (like the one you get with the iPhone) from eBay for $1.99 ($1 million in the Apple store). So that should make life easier for me.
akophone
Aug 1, 2007
300
Apple repaired mine for free.
ravman
Oct 4, 2007
1,197
Mean Streets of LA.
My original one is not faulty, it works fine. I just want one for the office and one for the home. I'm greedy like that.
adseguy
401
They all work the same way, but the WAY the iPhone charges is because of the lithium-ion battery. It will rapidly charge to about 90% in 2 hours then take that last 10% and trickle charge it to 100% so as, over time, not to damage the battery.
It does not matter if you use the iPod charger or the iPhone charger 5 volts is 5 volts.
ravman
Oct 4, 2007
1,197
Mean Streets of LA.
This is what I mean. It takes 5 hours to charge just 10% (using the iPod USB charger). Not to 90% and then the 10% trickle. When I plug the iPhone into my PC, it fully charges in about 3 hours.
Weird?
Jul 6, 2007
1,832
26
Marietta, GA
about.me
Weird?
yah its very weird, i used my old ipod charger for a while (not an Apple one though) and it charged just as fast as the iPhone charger
