iPod with expandable storage
nicekid
Jun 21, 2006
19
could anyone clue me in as to which ipods have expandable storage and how to hook those memory cards to a pc? thanks!
TheFron
Jun 18, 2006
30
I don't think any has expandable storage, but I do know the 1st generation is able to be used as an external harddrive (or flash drive rather) via usb connection (I think it may be firewire usb).
Addicted
Jun 20, 2006
14
er.. even i am not sure .. but as far as i know it does not have nay extended storage? and yah the first generation were used as the external harddrive... and yeah it also requires a usb connection... you seem to know a lot about it Fron... great!
Savannah
Aug 11, 2006
19
The Fron is 100% correct on this one. None of them really have external storage but the Generation 1's can be used via a usb cable as a flash drive. Hope that helps you out some.
you2
Nov 22, 2006
61
I have never heard of iPod with expandable storage.I have a fifth generation iPod and it doesn't support this feature.
But the idea sounds great.The question is how it will be implemented. But surely it will provide great flexibility once it is done.
