iPodME v.2
Dec 8, 2008
619
N
Very good converter, it has multiple setting of "slow/quality........up to fast/size" It is extremely fast, only takes 15 minutes for "slow/quality" which has the best quality, doesn't take much memory and converts to MP4 (almost any file to mp4) it is free, google : IpodME. Extremely simple to use and required no previous knowledge of converting....have fun
Dec 8, 2008
619
N
It must be a zip file you downloaded, depending on what operating system you have, right click and select "extract all". That shoukd open another folder and you can open it up... Double click the "black icon". Which is the program and add files and then convert....
I downloaded my file from a link i found in the "lifehacker.com" web site... U can follow th same link by goinf to the site and searching on the second page.....
Dec 8, 2008
619
N
It is a windows only program, so it will work only if you have windows..
