Is an App Draining My Battery?
fanboy
Feb 5, 2012
84
I jailbroke my 4S sometime ago & am enjoying it.
Recently I added Barrel through Cydia, and just before adding Barrel I updated my Apple apps (they had not been updated in a long time). Shortyl after that I noticed my battery died in less than six hours.
I uninstalled Barrel and set my e-mail from push to manualy fetch. My phone is still loosing about 10-15% per hour.
When I turned off my data the drainage stopped. This tells me an app is doing the dirty work. Is this correct, and if so how can I find out which specific app is killing my battery?
Dec 15, 2008
5,386
340
Pensacola, FL
We may be able to assist you if we know what applications you run the most and which ones stay running in the background. You can close running background apps by double tapping on the home button.
fanboy
Feb 5, 2012
84
thanks. I only run a few, but I close them via doulbe press home button.
I run the most are text, mail, tapatalk, facebook. Since the issue surfaced I have closed them everytime I use them.
Recently I closed/cleared the apps out and did not open them all day. My battery is still draining. I have turned my mail to fetch only thinking that was the problem. No luck. Would you like me to post all the apps on my phone?
Dec 15, 2008
5,386
340
Pensacola, FL
How bad is your battery draining? It is normal to drain 10-15% throughout the day even without being used. Using text, mail and Facebook will cause the battery to drain much quicker.
If you would like to post your apps on your phone, you can. But I believe we should focus on the apps you mainly use on a daily basis. You believe it's an app. I just reread your first post that says you are losing 10-15% an hour. I'm sure you want to stay Jailbroken, but have you tried a full restore as a new phone? Before even thinking about this, have you tried a hard reset where you hold both the home and lock button until the phone shuts off and the Apple logo reappears?
fanboy
Feb 5, 2012
84
My battery is draining 15-20% an hour. I'm not contstantly on my phone.
I just tried a hard reset, I did not even think to do that. We'll see what it does today, I'm headed in to work now. But now I have a bigger problem. I posted already in this forum. My contacts vanished from my phone but they are in iCloud. http://forums.everythingicafe.com/threads/contacts-disappear.69189/
Dec 15, 2008
5,386
340
Pensacola, FL
I responded to the contacts issue. Keep me informed about your battery issue.
AeroCare
Jul 16, 2009
1,210
25
All over the World !
So did the hard reset do anything for your battery drain issue?
fanboy
Feb 5, 2012
84
No the hard reset did not work, the reset from settings seemed to have done the trick. I have no issues with battery drainage now.
Unfortunately I never found out why this was occurring because I had another problem appear and synced my phone instead of resetting and then syncing.
I'm sorry I did find out what the problem was to contribute, however, the reset fixed whatever the issue was.
28,405
5,536
Resetting all settings helps with various problems. I used to have to do that about every four weeks on my old iPhone 4 to keep Bluetooth working satisfactorily. Of course, a full restore would have had the same effect, but this was easier. It only takes me about five minutes to set my phone back up after resetting the settings. It's perfectly fine for jailbroken phones, too.
28,405
5,536
RESET ALL SETTINGS is ok for jailbroken phones? Why would they create the tweak RESETALLKILLER ?
You can't Erase All Content and Settings on a jailbroken phone. That option gets automatically disabled as a safety feature when you install the newer jailbreaks since attempting to use it while jailbroken resulted in getting stuck at the boot logo.
You can, however, Reset All Settings on a jailbroken phone. That's always worked and still does. I've been doing it for years on my jailbroken phones.
Someone who doesn't fully understand this made the RESETALLKILLER tweak. They should have just had it disable Erase All Content and Settings and left Reset All Settings alone. It's a moot point if you're using evasi0n since it already disables what you shouldn't do.
AeroCare
Jul 16, 2009
1,210
25
Someone who doesn't fully understand this made the RESETALLKILLER tweak. They should have just had it disable Erase All Content and Settings and left Erase All Content and Settings alone. It's a moot point if you're using evasi0n since it already disables what you shouldn't do.
Typo?
28,405
5,536
Yep. Just fixed it.
AeroCare
Jul 16, 2009
1,210
25
So if I remove that tweak, what will RESET ALL SETTINGS do? Will I have to then go back and restore from backup and also use PKGBACKUP?
28,405
5,536
Retting All Settings isn't a restore and it doesn't remove any apps or data. It just resets your phone to stock settings. Third party app settings are retained (this includes Cydia apps), but it resets the phone to its default settings. You'll have to put your WiFi passwords in again, set your wallpaper, set your ringtones, and other things like that. It also removes Shrink's settings, for example, since they are part of the layout. You'll get the grey welcome screen when it's complete.
28,405
5,536
I guess I'd also have to setup all my emails and passwords etc. I'll keep that in mind, thanks.
No, email accounts and passwords don't get removed. It should take less than five minutes to get it set back up. In addition to wallpaper, ringtones and WiFi passwords, I just remembered that you also have to put your voicemail password back in and set up fetch times for email (since the default setting is push with manual checks). There are a couple other settings like that I'm sure I'm forgetting.
AeroCare
Jul 16, 2009
1,210
25
No, email accounts and passwords don't get removed. It should take less than five minutes to get it set back up. In addition to wallpaper, ............. and WiFi passwords, I just remembered that you also have to put your voicemail password back in and set up fetch times for email (since the default setting is push with manual checks). There are a couple other settings like that I'm sure I'm forgetting.
Thanks, I'll keep this in mind in case I have any weird issues I can't figure out.
EDIT: I had to edit your post. Apparently you have to be a Moderator to write the word "r i n g t o n e s". This is what I get when I tried to reply to your post :
