Is it okay to upgrade to 1.1.1?
Oct 26, 2007
I ran ver. 1.1.1 for a bit when I had the phone (new) and I downgraded to ver 1.0.2 because I heard of the flaws of ver. 1.1.1. They just came out with ver. 1.1.2 so I am wondering if it's okay to upgrade to ver. 1.1.2. I want to run the app. "stack" on the iPhone and thats the only reason why I want to upgrade.
Should I avoid this upgrade and just wait it out?
Thanks in advance.
Youngbinks
Jun 4, 2007
7,617
31
Atlanta, Georgia
Are you jailbroken or unlocked? If not then there really isn't a reason NOT to upgrade.
Oct 26, 2007
Youngbinks,
I am really unfamiliar with the term jailbroken even though I see it all the time on here. I am assuming jailbroken is where you have different applications such as summerboard, etc. and unlocked is where you can used it with any services? Correct me if I am wrong.
But I bought the iPhone from the AT&T store and service through AT&T. So my phone is jailbroken?
jjvaldez
Jul 3, 2007
2,615
33
Salinas, Ca
if you didn't jailbreak it then it is not... it is stock... jailbriken is something that you have to do to it, [summerboard, etc.] unlock is when you are using it through another service other then att...
seems that you are still stock...
