is it possible to create a podcast button?
hairyfil
Sep 27, 2008
Hi,
I use my touch mainly for listening/watching podcasts. Getting to them isn't that smooth, clicking on music, then more, then finally podcasts. It would be far better if I had a dedicated podcast button that I could have on the main bar. Is it possible to create one?
thanks
Phil
fury
Oct 23, 2007
2,274
238
33
Louisville, KY
No, but you can get one step better - go to Music, then More, then Edit. You can then drag Podcasts into place on the Music app toolbar, over one of the existing icons. I replace the Artists button with the Podcasts button, for example. Anything not on that toolbar gets put into the More list when done.
hairyfil
Sep 27, 2008
Great
Thanks for that tip, that makes getting to the podcasts that little bit easier now.
cheers
Phil
