Is it possible to downgrade from 3.0 to 2.0?
amk5047
Sep 18, 2009
I purchased the update when it came out to 3.0 and was wondering if it was possible to downgrade to 2.0?
syxR
Jan 1, 2010
You could probably restore your iPod to factory settings, and then it may be on 2.0. If it was shipped below 3.0 it should restore to whatever it shipped with
canamera
Dec 28, 2009
2,756
79
42
Toronto Ontario, Canada
I don't think you can...As soon as you upgrade, your there for good.
Someone please correct me if I'm wrong.
LakerLover
Jan 4, 2010
20
why would you want to?I think if you click ctrl(key)and press update you get to choose whoch one.Its either Shift or CTRL
simba33
Oct 21, 2009
716
27
Kingsburg CA
www.ebwebcreations.com
uhm no it doesn't, it restores to the latest firmware thats out at the time of the restore. you can download different firmware from other sites and then use shift+click restore and select the firmware you downloaded but i have never heard of someone downgrading from 3.0 back down to 2.0. sorry but your stuck at 3.0. why would you want to downgrade anyway? 3.x series of firmware can be jailbroken.
jfairnie
May 30, 2010
Downgrade to jailbreak the system. You can downgrade but you have to use right firmware. I also think there used to be software for restoring the 1601 error in iTunes
Sep 8, 2010
Downgrading is very much possible. The hardest part is finding the files you need to do the job. Downgrading from 4.0.1 to say 3.1.2 is achievable. I did it because 4.0.1 had issues with cydia's apps. There are now a lot more compatible apps/tweaks for the 4.0.1 firmware.
The files that you need to downgrade are:
* " LibUSB64 "
* " iH8sn0w - iREB V3.1.2 for windows"
I am running a 64bit system so these files work for that.
If you have problems finding the files let me know and I will sort something out. Google was my friend that's how I found them.
Geeza
Sep 8, 2010
14
Yes, download iOS 2 (from google ect) and you can import into iTunes and make it restore to it
