Is it possible to selectively choose apps from iPad to iPhone?
capri
Jan 1, 2012
77
Hi guys
I have roughly 100 apps in my Ipad & would like to probably use 20 of them in my iPhone 4s.
Is it possible to selectively choose just 20 to move to the new iPhone 4s ?
How is this done ? and is it possible to do this without the use of the macbook or Imac ?
Thanks in advance.
Tattooed Alex
Oct 24, 2010
3,050
809
Denver, CO
You can download the iPad apps to your iPhone through the purchased app section of the app store, go to not on this iPhone and the apps will show up with a cloud next to them. You can only download them one at a time through the iPhone. I don't have a Mac and have never tried multiple apps at once on my pc.
Sent from my iPad using iCafe app
capri
Jan 1, 2012
77
go to not on this iPhone and the apps will show up with a cloud next to them kindly clarify above statement
verwon
Jul 29, 2011
1,015
121
Seattle
First, turn off auto-downloads, under settings, store.
Then open the app store, tap where it says updates and you'll see purchased at the top. Select that and you'll get a full list off all your purchased apps, so just install the ones you want on your iPhone! :)
