Is it possible to upgrade from iOS 5.1.1 to 6.1.2?
May 23, 2012
Agra
I was on 6.1.3, downgraded to 5.1.1 through redsn0w using SHSH Blobs. Is it possible to upgrade to 6.1.2?
Sent using iCafe app
RoofMonkey
Jun 21, 2010
8,894
2,058
If you device is still jailbroken, I do believe you can.
Kadelic
Jan 4, 2010
4,947
1,646
Dallas, TX
I'm afraid that blobs for 6.x are currently worthless. You're stuck where you are or upgrading to the current firmware being signed.
Edit: Please ignore my post. I didn't notice the post was made in the 3GS section.
5,578
If you have full 6.1.2 SHSH blobs for your 3GS, you can create a custom 6.1.2 firmware and stitch the blobs to it. Use iFaith to see if you have a full or a partial SHSH.
The alternative is to use a semi-tethered 6.1.3 jailbreak.
Kadelic
Jan 4, 2010
4,947
1,646
Dallas, TX
:oops: Oops, I neglected to notice this was posted in the 3GS section. Begging you pardon. :oops:
May 23, 2012
Agra
I accidentally upgraded to 6.1.3. Did a tethered jailbreak through redsn0w. But it was useless, cydia wasn't working. Every time I opened it, got crashed!
Then I switched back to 5.1.1 (thanks SHSH blobs) :)
The reason for switching back again to
5.1.1 is that it is consuming a lot of battery + the feel and look of iOS 6 was awesome!
May 23, 2012
Agra
I don't have SHSH Blobs for 6.1.2.
5,578
You can't restore to 6.1.2 then, unfortunately.
You could try the semi-tether on 6.1.3 again. It might have just been a Cydia glitch last time.
