is it true? about unlock
coolie
Sep 18, 2007
131
i unlocked my phone with iunlock. i just want to know if it will work in vietnam. becasue i heard someone said that you have to open it and do something to it before you can use it in Vietnam
SkyyBoy
Jul 4, 2007
131
Hawaii
GSM is GSM (assuming that the unlock worked properly).
before you go, borrow a friend's T-Mobile card just to make sure the unlock worked.
once you get there, just buy a pre-paid sim, insert the card and enjoy!
AFAIK, no pre-paid provider in Vietnam offers GPRS (or EDGE) on their prepaid plans (so only data available to you will be WiFi)
my last trip to Vietnam, I used my factory unlocked HTC TyTN there with no problems with a local SIM card (Vinaphone, i think...)
