Is Modding It Hard?
dietPEPSI
Jun 29, 2007
80
After looking at some of the mods people have....i want to do it so sooo bad....
But I just don't want to screw anything up....
Is it a long difficult process? Or can i just downloaded mod zip folders and unzip them and im good?
Or what happens when you mod the phone? What do you need to do?
princess_80854
657
It's not hard. All you need is a little time and patience. You can read here to get answers to your questions and learn how to get started. Good Luck!:)
http://forums.everythingicafe.com/threads/read-this-iphone-modding-info.5860/
dietPEPSI
Jun 29, 2007
80
dietPEPSI
Jun 29, 2007
80
alright after looking further into this im just not gonna do it at the moment.......looks way to hard....
If thats the only way i think its way too difficult....
princess_80854
657
You have to do them one at a time.
You can't go wrong. They have screenshots of every step!
You can always restore you phone in iTunes to it's original state.
Go for it!:laugh2:
iPhobos
Jul 25, 2007
201
Don't worry! You aren't alone. There has been quite a few people that were tentative about modding their iPhone. But after reading through the instructions and asking questions they found it easier then they thought before hand. I would suggest checking out Manzana, it is a user GUI that may make it easier to mods your iPhone. You can find it here at code.google.com/p/manzana . Try it out and don't be afraid to ask questions, most here at EIP are more than willing to help. Don't forget to read the stickies in the Modification forum for a better understanding of what you are doing.
As stated by others, you can always restore using iTunes.
Good luck!
dietPEPSI
Jun 29, 2007
80
Good luck!
I just downloaded Manzana....what do i do with it? Do i put it in the phonedmg folder or something?
jgolden
Jul 19, 2007
I was in the same position as you...the 10 steps are easy, and with drag and drop, its a piece of cake! I've changed all my icons, the battery, status bars, and AT&T symbol. Its great, I like the way the mods look.
I was afraid too, but its really a piece of cake.
princess_80854
657
Yes, you put the Manzana app along with the .dll file included with Manzana in your "PhoneDMG" folder.
princess_80854
657
Did you follow the instructions given in the link I gave you in my last post? You HAVE to do that first.
dietPEPSI
Jun 29, 2007
80
sorry bout that....i didn't have a .dll file in there, i forgot to drag it in
And anyways i opened up manzana and i still have no clue what im supposed to be doing...is there a tutorial on this site anywhere for modding iPhones using manzana?
dietPEPSI
Jun 29, 2007
80
What is terminal?
" Go to your Applications folder and then go into the Utilities folder and find the program called Terminal. You should move this to your dock for easier access. Note that when typing in the terminal, everything is case sensitive. So watch your capital letters and lower case letters. Do not interchange them, they won't work. "
Im guessing it has something to do with Apple computers....is the Command Prompt the same? The only thing is I think the directions are different, because the instructions don't work in the CMD prompt
dietPEPSI
Jun 29, 2007
80
another thing....
When i run iPhoneinterface....it starts up, and then closes down before i can do anything...it says
Waiting for phone:Established
iPhone state: Activated
right after i get that message it closes on me...
Whats wrong?
qryptiq
Jul 21, 2007
75
are you at the command prompt (this is known as the terminal)? or are you double-clicking on iPhoneinterface file?
also, i've noticed there are a couple of "versions" of iPhoneinterface out there. You may want to try them all and see if you get different results....be patient
dietPEPSI
Jun 29, 2007
80
Sorry about all these dumb questions......but now im attempting to use Manzana....people here said it was a lot easier because you can just drag and drop.....
I read some thing that gives me a directory to put the icon pictures.....but what the hell...they arent here..
qryptiq
Jul 21, 2007
75
Well this is all I get...
maybe it's jailbreak.....something didn't go right....again have patience.....here's what you can do......restore your iPhone....run jailbreak and try again.....
princess_80854
657
You have to run Jailbreak before you can do anything else.
dietPEPSI
Jun 29, 2007
80
do i need to do the thing where i put it in restore mode or something? Like by holding home and the power for 25 seconds? Or does that not matter when using Manzana
dietPEPSI
Jun 29, 2007
80
when i do the thing in Jailbreak where i hold down power and home for 25 seconds....after its done it just gets stuck at please connect to iTunes...and i thought i wasn't supposed to open iTunes
princess_80854
657
