Is my iPhone locked or unlocked
Discussion in 'iPhone' started by Skull2006, Feb 1, 2011.
  1. Skull2006
    Skull2006 New Member
    Nov 14, 2010
    Dear All,
    i have iPhone 4 4.1 JB from ebay.
    i want to know is my iPhone locked or unlocked?
    BR,
  2. Chris5956
    Chris5956 Member
    Aug 3, 2010
    Put your sim inside of it and if everything works then it really doesn't matter as long as it's working for you
    If not, you should be able to unlock it
  3. Avatar
    Sponsored Advertisement
  4. Skull2006
    Nov 14, 2010
    it's work, but i want to make update from iTunes.
  5. RoofMonkey
    RoofMonkey Genius
    Jun 21, 2010
    1,652
    DO NOT do updates to the phone. If it's an update just for iTunes, that is ok. Just don't update the phone to a newer firmware (4.2.x) or you will loose tour jailbreak and have to redo the unlock, of its unlocked.
  6. applejailescape
    Oct 5, 2010
    20
    Yeah like roofmonkey said don't update , you can click cancel (while Ipsw is downloading) if you pressed update by accident .
  7. Europa
    Europa Moderator
    3,970
    Actually, it's an iPhone 4, so he won't be able to unlock it. If he relies on an unlock and updates in iTunes, he'll get stuck at the emergency call screen and be forced to jailbreak and hacktivate with redsn0w. If he doesn't have his 4.2b3 SHSH, it will be a tethered jailbreak. There is no unlock for 4.2.1 on the iPhone 4, so his sim card won't work and his iPhone will be downgraded to an expensive iPod Touch.
    Skull, beware of the update button if you rely on an unlock...
Share This Page
