is my phone broke :(
Pharaoh
Sep 7, 2007
91
I can't hear out of the speaker any more it just started today. Can't hear on calls or voicemails. I can only communicate through speakerphone. Should i try a restore?
I DO modify.... If that matters. Someone help? Im sad :(
patrick_83
Oct 11, 2007
310
Illinois
Something in the modding that you did could have had an effect i would just restore and start over myself :(
Oct 19, 2007
This is a known issue with some iPhones, Try putting the headset back into the jack and pulling it out a few times, that should resolve your issue.
Pharaoh
Sep 7, 2007
91
worked in one try, thanks so much man
connie
Jul 11, 2007
2,839
104
So Cal
This problem is very common and usually the headjack thing works so always try that first before restoring. I am glad it worked for you.
iAttorney
Sep 30, 2007
90
Houston, TX
The same thing happened to me. I tried the jack trick like 20 times and nothing. I called Apple care, they gave me the speal about sending it in and getting a loaner phone (at no charge though). I told the guy I would try a restore, and hung up. I got on the forums, saw that the jack trick usually worked, and then did it again. This time I inserted the jack around 5 times in a row, rather quickly, and now it works fine.
My google maps app went crazy the other day to and I had to restore it. Man, when the bugs come, the infest...
