Is there a size difference with the new 3G?
May 30, 2008
21
I see many cases that say they are for the iPhone 3G and do not know if they will fit my original iPhone.
aenti
Jul 8, 2008
1,155
Maryland
3g has tapered edges. It is thicker and wider.
Some v1 cases has the tendencies to fit, most cannot.
May 30, 2008
21
I asked because I wanted to know if the new one is a different size than my ORIGINAL iPhone.... I don't have the 3G so I didn't post it there!
sheesh!
May 30, 2008
21
NOTE the topic? Size difference was what I asked about....the comment about the cases was an add on -- I didn't specifically ask about the case. Why so darn worried about where you think a post should be? It's just a post.
May 30, 2008
21
Can we just delete this stupid thread?
aenti
Jul 8, 2008
1,155
Maryland
Why so serious?
Anyways if it angers you, I'll edit stuff out. But you got your answer?
May 30, 2008
21
Nah, not being too serious...it's hard to be tell what someone means when you you read typing and cannot hear the tone in their voice. Your typing just seemed kinda snooty at first, is all. All is well.
aenti
Jul 8, 2008
1,155
Maryland
yes, I know. I tend to sound very aggressive/"snooty". In reality, I am not. I don't know, how would you suggest I fix it?
May 30, 2008
21
You are who you are, so don't change! (BTW..I am a bit "sensitive," if you couldn't tell, he.)
Aw, our first fight! Lol...j/k.
Group hug!
(It's pretty sad...I am totally amusing myself right now.)
ThunderBull4
Jul 28, 2008
40
Well this is what i found... not sure if it's right:
iPhone3G
Height: 4.5 inches (115.5 mm)
Width: 2.4 inches (62.1 mm)
Depth: 0.48 inch (12.3 mm)
Weight: 4.7 ounces (133 grams)
iPhone - Technical Specifications
* Height: 4.5 inches (115 mm)
* Width: 2.4 inches (61 mm)
* Depth: 0.46 inch (11.6 mm)
* Weight: 4.8 ounces (135 grams)
I didn't do the conversions.... 3G specs came from Apple.com, and reg iPhone specs came from http://support.apple.com/specs/iPhone/iPhone.html
(so both Apple)
