Is there a stable Jailbreak for iOS 7.1.2 for iPhone 5?
Oct 28, 2008
20
I was thinking of One Click by Pangu. However, it appears unreliable. Users reported Safari not working after a few days.
Is there another untethered jailbreak method that is reliable?
Oct 28, 2008
20
Several complaints from different users about it (Safari) and a few other nuances on evad3rs.net and iphonehacksdotcom.Also different comments about long load times eg. loading resources. I don't have privileges to post links so I can't provide it to you.
28,365
5,506
Pangu works great. I'm still using version 1 and it's very stable. Some people experienced problems with Safari on version 1, but there is a fix for that. It's a non-issue now. Pangu is your only option.
Oct 28, 2008
20
thx. so would you say I should go for it then, install Pangu on my iPhone 5 or wait until the other untethered jailbreak from evasi0n7? btw, will this jb will block the OTA update download of system (firmware) update from being downloaded?
Napoleon PhoneApart
Jun 19, 2007
33,474
4,542
Upper Marlboro, MD
I'd go for it now. You could be waiting for some time for the next major jailbreak.
And yes, Pangu blocks OTA updates on your iPhone.
Oct 28, 2008
20
Excellent...it took a couple attempts but my device is now
You remembered to set the date back, right?
I think that was the problem. I was changing the date and then Pangu started to do it's thing. My device was also p/w locked. I disabled it and change the date. Now, it's jailbroken :)
However, a lot of files have been added to my device. I was at 10.3 GB and now I am down to 9.7 GB. Is this normal? I'd like to delete what is not necessary after the jailbreak.
Oct 28, 2008
20
Haha. Hell no. Not wishing to delete "necessary" files, just those files which are no longer dependent on necessary.
I imagine iCleaner is ok though to use?
BTW, I noticed my iPhone cellular signal strength indicator takes much longer time to change/after after this JB. I have it set to show the dB (*3001#12345#*)
Oct 28, 2008
20
Here is the instructions on how to show your dB:
Step 1: Dial *3001#12345#* on your iPhone then press Call.
Step 2: You'll now enter Field Test mode. You'll notice a signal strength indicator on the upper left hand corner of your screen. You can toggle between signal strength bars and a number by simply taping on it. At this point, press the home button to exit the app or if you would like the feature to be permanent, continue on. Don't worry, the process is completely reversible.
Step 3: Hold down on the Power button until you see the ‘slide to power off' bar. Do not power off the device.
Step 4: Press down on the Home button until the app closes and you return to your home screen.
That's it. Even when restarting the iPhone, the signal strength can be toggled between bars and numbers. The closer your number is to zero, the stronger your signal is.
The lower your number, the stronger your signal—but don't include the - sign when evaluating (so, if the signal says -60, that's better than -90).
To return to the default bars permanently, follow these steps:
Step 2: Press on your Home Button once.
As far as my Jailbreak is concerned, I am not a happy camper. It's not stable. My Chrome browser is crashing on sites that are not mobile friendly. I tried the same web page on an non jailbroken iPad and I had no issue. My Heywire app crashes as well randomly. These are all unjailbroken apps. I will be posting a separate thread on the subject.
