Is there a way to delete temporary data?
TheFamousOne
Jul 12, 2008
95
So Im not sure if its even nessecary, but I thought I'd ask. Does the 3G store temp internet files/cookies/other data? Reason I ask is there is over a gig and a half of "other" items on the phone, and I doubt its only apps. What's taking up so much space?
Saverino
Jun 1, 2008
4,480
92
Burbank
Go into Settings -> Safari -> and then there are options on the bottom to clear history, cookies, and cache.
Hoshtaylor
How about temporary contacts in email...?
for example, I deleted this person from my contacts but when I go to compose an email and I hit the first letter of their name/email address, their email address shows up.
How can I delete that...?
Voltaic Shock
Aug 15, 2008
265
Leesburg, VA
I don't think you can without resetting everything on the phone under settings.
showguy
Dec 2, 2007
769
Long Island, NY
I think deleted contacts are gone for good once you sync with whatever contact manager you are using.
TAEWING59
Jul 12, 2008
344
same here... I send pictures to my friends all the time so slot of my contacts have there mms address as an email address... I use the label "mobile" for that... But if I they have changed there number and I change it in my iPhone... When I start to the there number or name of still lists the old one...
tbs
Aug 23, 2008
47
I had 1.25GB lost data space. I had rented a movie from iTunes and when the rental expired and the movie was deleted it did not return the free space. Someone on this list told me to reset the phone which I did and that did the trick.
Try resetting your phone to see if that helps.
Hoshtaylor
I'm new to the iPhone and the whole syncing w/ iTunes thing...what exactly are you referring to when you say "reset your phone" and what is the process...? Does it do a "master reset" of the entire phone and then you just re-sync w/ your computer...?
kenneth
Aug 19, 2008
1,465
Texas
Try holding the power button on top and the home button on the front until the phone shuts off automaticly. Once the phone is on the black screen simply push the power button and turn the phone back on.
Just tried this...the temporary email addresses are still there...
dturner
Dec 15, 2007
5,725
Louisville, Ky.
As far as I know of these can't be deleted. Way back when I got the V1, I sent myself an email to test it out and see if it was working. I typed in .con the first time and to this day with the 3G it is still with me. So now if I was to bring up my address in email, I have 2 to choose from. Now if I had done that on another contact, it would be a real pain to have to be careful to not choose the wrong one.
Hoshtaylor
What a pain in the a*s...do you think there is an app to fix this...?
At there very least, a sync should get rid of it if they are not in your contacts...
Does a "master reset" work...? I was going to try it today, but it said it would take like 2 hours...I'll do it tomorrow morning if it will work...
Hoshtaylor
Just so you all know...I've spent over 3 hours this morning erasing ALL data on the phone and reloading it. Turns out that email address is STILL THERE. I'm assuming because it was there when I backed it up this morning and the phone is just restoring to it's original point.
What a joke. Why is it so freaking difficult to delete a "temporary" email address...? Anyone...Help ?
dturner
Dec 15, 2007
5,725
Louisville, Ky.
You would have to restore as a new phone to solve your problem. Of course you would loose everything else.:mad:
failsafe
Oct 17, 2008
153
San Diego
BossPrefs has a new toggle that will clean up addresses from mail.app. Not sure if you've done a jailbreak yet but if so check Cydia. App is called ABRecentCleanup BossPrefs Toggle
Thank you failsafe...honestly I don't know anything about what Jailbreaking is...do I need to do something to my phone to install that app...?
I just wanted to update these two threads on this topic...I imagine that it's been nearly 2 months now since I tried to delete the temporary email address that I wanted to delete....long story short...it's gone now.
So I would have to assume that after all the things that I tried and didn't work, my best guess is that there is some kind of time limit or expiration for temporary data that is not used so it's then cleared/deleted. I'm not sure how long, but this seems to be the logical explaination.
Thoughts anyone...?
