Is there a way to download
jcmitchell5
Feb 19, 2010
602
57
Arkansas
Apps that are compatible with the iPhone 3G? The 3G can only be upgraded to 4.2.1 and the new Facebook and most other apps are past that firmware? Am I SOL or is there a way to download later versions of the apps?
fijiman
Feb 13, 2011
832
64
UK
Even if you could download the newer apps, they wouldn't function on your iPhone.3G...
jcmitchell5
Feb 19, 2010
602
57
Arkansas
I know that. I just don't see why you cant download the apps at the earlier firmware. It should have them saved so you can still use apps on all the iPhones. I don't really care much as I am getting the iPhone 5 in 4 days, but I just don't think it's very cool of the developers and Apple to drop their older phones...
fury
Oct 23, 2007
2,274
236
35
Louisville, KY
The iPhone 3G is over 4 years old now and is too limited in processor technology to support the newest OS while retaining some semblance of a decent user experience. It's hard for them to keep up support for a device with such limited capabilities without hindering support of newer devices and restricting the amount of features that can be added. That goes for both Apple and app developers. They had to choose to compromise on behalf of newer devices at some point. Otherwise, iOS 5 wouldn't have been as good, apps wouldn't have been able to take advantage of newer stuff, etc. I am actually surprised it kept getting updates for as long as it did (about 2.5 years). That is an eternity in smartphones.
In other words, to continue targeting for iOS 4.2.1, developers would have to sacrifice functionality. In order to update the 3G past 4.2.1, Apple would have had to sacrifice even more features from the OS. Truth be told, it should have never gotten iOS 4 to begin with. It's mind bogglingly slow on that OS.
Once an app has been updated to require higher than 4.2.1, the only option is if you still have the old one in your iTunes library or in your trash folder. If you find it in your trash folder, you could delete the new app out of your library and drag the older version back out of the trash, then double-click it to add it back to iTunes.
  • Like
Reactions: Caliphone
