Is there a way to have individual album artwork for box set purchased from iTunes?
Adam1389
Nov 20, 2008
588
Ilwaco, WA
Question..I just downloaded from iTunes a complete Metallica collection..It didn't download as separate albums like I thought it might, so it has one album cover for all the songs...Is there anyway to change the art? I made playlists to separate the songs into their respective albums, and want to change the art work for each playlist if possible.
Youngbinks
Jun 4, 2007
7,617
32
Atlanta, Georgia
You should be able to select the song (or songs) and right click. From there you should see a few different tabs and one will be labeled "Artwork". Click on that tab and you can delete the current artwork and either drag and drop in or paste in the new artwork you desire.
Adam1389
Nov 20, 2008
588
Ilwaco, WA
Ah found an easier way, just select all the songs, and change the Album info to the actual CD name. Thanks for the reply though.
