Is there a way to keep my iPhone awake longer?
ftobe
Aug 1, 2007
Actually I have a few questions:
1. I'd like to make the sleep time longer - say 45 seconds. How do I do it?
2. Can I bypass the opening slider (or password) and just get to the main menu when I press the button from sleep mode?
3. How do I add a widget or two?
4. How do I look at and manipulate files on my iPhone? I can't see the details on my MacBook Pro. What's the trick?
5. Since I can't play anything from YouTube or Google Video, can I delete the widget? How?
6. How do I change an e-mail address on my iPhone?
Thanks,
Frank
princess_80854
657
1. Go to Settings, Auto-Lock, and choose your preference (Your choices are 1-5 minutes and never)
2. No, you always have to use the slide to unlock to access the homescreen.
3. You can't. You can only view WebApps in Safari.
4. You can't change the files on the phone. The only thing you can do is change the graphics or add/delete ringtones.
5. You can't delete the widgets from the phone.
6. Go to Settings, Mail, and change your preferences.
