Is there a way to send contacts from iPhone to Outlook?
Antmf
Jul 29, 2008
42
Is there a way to send contacts from iPhone to outlook ? For example I add 10 new contacts on my iPhone and want to have it sent to my outlook. Is there a way to do this or do i manually have to put it in? Thanks...
PapaST
458
Wouldn't synching the phone do that for you? Of course you would want it set in your iTunes... but yeah I think just synching the two together would do the trick.
showguy
Dec 2, 2007
769
Long Island, NY
What your asking is a basic job for the iPhone and iTunes. Start iTunes, plug your phone into your computer via a usb port. Make sure iTunes is configured to sync your contacts with outlook (that should be the default setting) push the sync button and your done. Do this whenever you add a contact to either the phone or outlook and it will sync to the other.
Antmf
Jul 29, 2008
42
Thank you for the replies. By George I think I've got it ... :)
rasputinj
Jul 18, 2007
46
I have done it over the air, using nuevasync then to Plaxo and then to Outlook, it has worked out well, I also sync my calendar over the air also with nuevasync.
