Is there a way to update album art not from iTunes?
alinton
Oct 28, 2007
Hi all,
Is there a way of putting album art onto the iPhone if my music is NOT from iTunes?
Most of mine isn't, but maybe there's a way?
Andy.
binLatin
Nov 4, 2007
25
Yes all you need is the album cover or any image you would like to use, good place to find some album covers is on google image search. Then simply open up iTunes and right-click on the file(s) you would like to use that image on and click on get info then select the tab "artwork" and then click on add and search for the image on you harddrive and click "ok" or you can simply drag the image itself onto. Another method is opening up iTunes and let iTunes itself search for the covers by click on the "advanced" tab in iTunes and selecting "get album artwork", but this method doesn't work on all files.
