Is there a way to update album artwork for songs not purchased in iTunes?
iphone62907
Jun 25, 2007
100
is there a way iTunes can automatically give my songs album artwork even if i didn't purchase the song from iTunes
jda182
Jun 16, 2007
148
if you right click on a song and look at the bottom it says "get artwork" but i can't get it to work
i used fixtunes just google it
you can use it for free for the first 50 songs, after that you have to buy it for $25. i used it on my 2500 songs and it found artwork, album, etc for 2000 of them and 1900 of those 2000 were right, so it worked on 1900 of 2500 songs. which i thought was pretty damn good.
iphonenut
May 17, 2007
373
a little advice if the album artwork isn't coming up for some...make sure that all the info matches up (i.e. correct spelling, caps, spacing etc.)
kcarr91
Apr 14, 2007
62
i found a way to get it for free (am i premitted to post here) just do it 50 at a time
have your program files open when you do 50 delete file called (cloudbrain) reinstall (only take 30sec total) it saves which ones you have already done
you have to check to see if they got it right for each one but it worth it
took me a couple hours for about 1700 songs
ColsTiger
Mar 8, 2007
5,856
Columbus, GA
If you didn't get them from iTunes or import them yourself from your CD collection, then you can expect to spend some time to get them all coordinated. P2P systems like Limewire are the worst for people misnaming the Titles, Artists, and Albums. iTunes can't find the album art if they're named incorrectly.
You might want to try that software listed above, because it took me two solid days to get mine straightened out.
420greg
Jun 26, 2007
845
Orlando, Florida
The Artist and Album name have to be a perfect match. The are some 3rd party products that are more forgiving, or will give you a list to choose from.
magnum man
Jun 10, 2007
100
I'm trying to figure out how do you have albums with multiple artists (soundtracks, compilations etc.) Not show up in cover flow as separate album covers for every song.
