Is there anyway to Adjust the bass or EQ on your custom ringtone
Skipper
Jul 18, 2007
45
Cool Edit pro will do that. don't remove all the bass, but add more treble, that way it just sounds like a ringtone from a lower quality phone, but still doesn't sound like its ripping the speaker apart.
And if you get Cool Edit, you can increase the mp3 volume so you can actually have loud ringers. its sweet!
PhatKid
Jul 25, 2007
128
If you have a Mac, which is likely, use Garage Band to make the ringtone. Then you can EQ the song to have a little less bass and hype the treble. Also, make sure that you export your mp3 with a higher quality.
iPhobos
Jul 25, 2007
201
Has anyone been able to make their ringtones sound great using WavePad? I have the full version and i am thinking about uninstalling and using Cool Edit Pro if that program is easier to use.
