Is your iPad getting hot?
chris
Administrator
Administrator
Jun 10, 2006
11,817
1,707
Long Island, NY
I was playing back a few videos this morning. It couldn't have been more than 10 minutes of playback, but I noticed the iPad getting hot on the back. I've never had an issue with the iPad 2 getting hot, ever.
Anyone else notice this new iPad running a bit hotter?
|3are
Jun 13, 2008
730
17
Texas
I haven't noticed yet but I also haven't done much long-term video-watching. I believe there were reviews posted a day or so before release saying that this iPad does get hotter. I think they blamed it on the larger-capacity battery. I'll try to find a link.
mbairguy
Mar 8, 2012
175
62
Birmingham, AL
I received my new iPad early yesterday and haven't opened it yet....I know...
Tinman says "left is left" which means hotter area where the cpu/gpu is located. This entire length is loaded with heat sinks over heat pads; over thermal paste. Heat transfer should be uniform (relatively) over the surfaces of the sinks. The aluminum (back) cover looks neat but also dissipates heat well. I would expect "this" side to be warm.
I haven't really thought about processor core temps for the iPad. So far, I haven't found an App that provides internal core temp? The A5/5x must have/use cpu temp to provide auto-shutoff. I know cpu-z works with certain ARM processors.
Unfortunately, my thermal imaging device is with my salesman in Ms. or I would shoot temps on both the iPad2 and new. Hopefully, someone will provide better benchmarks than what I have seen thus far. (including core temps).
  • Like
Reactions: glsda and chris
jarofclay73
Jun 23, 2008
2,387
Honolulu, Hawaii
My iPad 2 got hot when playing games like Real Racing 2. Just about every reviewer says the same about the new iPad. I guess as long as no one gets burned I suppose it shouldn't affect performance.
BoLoThaBeAR
Mar 9, 2012
69
Mine works lik a Champ! No overheating here
Sent from 'the new iPad' using iCafe app... GO BEARS! ;)
Troubleina
Mar 5, 2009
118
Suburban Washington DC
yup, mine to seems to get warm to the touch, not hot, but it's definitely warmer than the ipad or ipad2 was. I haven't watched videos on mine yet, just web surfing, and playing games.
Krunk83
Jun 28, 2008
4,605
My iPad gets hot. Lower left side mostly. Usually about an hour after heavy use. Not too hot to touch but definitely noticeable.
GailLA
Nov 13, 2007
265
35
Northern IL
Not really. I watched a 3 hour Netflix last night, an activity that I read would make it hot. It was warm, but not at all hot. And it is not that warm.
Tattooed Alex
Oct 24, 2010
3,050
809
Denver, CO
Haven't noticed yet on my new iPad. I don't think my 1 got hot either, but it was always in a case. My wife has never complained about her iPad 2 getting hot.
rom x
Jan 18, 2011
1,048
99
nothing out of the norm, just a little bit warn which is typical for such a device.
eye-Fone
Jul 5, 2008
1,024
14
Sunny, southern California.
Why is this such a surprise? It's basically the same casing as previous iPads, but with a much higher resolution screen, a more advanced CPU and GPU, and a larger capacity battery. To push that many pixels, the GPU has to work that much harder than lower resolution displays of past iPads.
How can you not expect it to run a little warmer than other iPad versions?
  • Like
Reactions: glsda
mbairguy
Mar 8, 2012
175
62
Birmingham, AL
Exactly. I have less and less patience with this stuff...lawsuits because Siri doesn't make the coffee and mow the damn lawn; "my new iPad set my pants on fire"... Thank goodness for the forums where myths can be dispelled.
42-watt battery vs. 25-watts...a 70% increase in power required...released in the form of heat energy...who'd a thunk it.
  • Like
Reactions: iphone1027
