iSafe Pro
Maxituch
Jul 30, 2014
Hi there, anyone using iSafe Pro? I am using it and it was good before the update. After update they changed login. Login with finger prints and it's not working now. Access denied when I try to login. Also, I can't see the setting page or on off finger print login. Any one know about it?
And as I think, they trying to sell their passwords reset app that's why they don't allow user to enable or disable finger print login.
28,365
5,506
Please only start one thread per topic. I deleted the other two.
You can't override the fingerprint scanner with a passcode? Try deleting and reinstalling it.
