iSEE clear plastic Case for iPhone 3G is horrible
coolnwo
Jun 8, 2008
9
I got this from Apple store today and its horrible. It is very sharp on the bottom so it cuts you but the worse thing is if you put the phone on vibrate you cant move it back to ring unless you take the entire plastic casing off. Just very poor design.
Here is a picture
http://www.contourcase.com/isee/iseeiPhone3G/
ibTom
Mar 21, 2008
30
Here is a picture
Yes, I have this one as well and I plan to retturn it. Like you said, you have to lift the case up a bit to go back to ring on the silencer switch. Also the silicon buttons cover for the power button and volume control make it a bit harder to operate. It also feels rather flimsy and I would bet if I drop my phone it will break apart on impact.
