iShare and Mobile Finder problem
kdam
May 14, 2008
Hi ya'll,
I downloaded Mobile Finder and iShare for GBA roms. I created the ROMs and then GBA folders under Media with Mobile Finder, but when I go to use iShare and download the rom, when I go to select the folder to put it into, nothing shows up in Media (where the ROMs and GBA folders should be). Does anyone know how to fix this problem?
tnabb
May 16, 2008
hey i think i know your problem. the same thing happened to me and i was struggling for hours. when u log in and stuff and you put in the 6 digit code at the end of the url, hit next at the top right, hit home, and instead of hitting media, hit the option with the dots (the option at the very top). then there should be a pretty long list. go down to mobile and hit that. then go to media, go down to ROMs, and the GBA and GBA again. that is where you hit select. i don't know if this will work for you but it worked for me. good luck!
kdam
May 14, 2008
thanks man, that was exactly what i was looking for
tnabb
May 16, 2008
no problem glad i could help ;)
ernest
Feb 25, 2009
um i have a problem with my ishare app it goes in loads then goes out by itself
