It never has worked ?
catsalleyt
Jan 26, 2008
50
Paloma, California
Everybody says Ibrickr is so easy to use.. Am I missing something? I have a jailbroken 1.1.3 phone. I used the ZiPhone jailbreak. I also installed the ibrickr fix with the installer. When I use Ibrickr it acts like its going to work but it never installs anything on my phone.. Is there another program I could try that would allow me to install files onto my phone?
Thanks!
bean22
Dec 13, 2007
65
If you have Wi-Fi then download a program called WinSCP to your desktop.(make sure you have BSD subsystem and OpenSSH installed on your phone)
Otherwise, you could try iPhoneBrowser.(doesn't require Wi-Fi, you connect via USB)
Hope this helps
catsalleyt
Jan 26, 2008
50
Paloma, California
Hope this helps
Thanks for the help. Im a novice and wanted to know if this program is for advanced users.. don't want to screw things up..
patrickj
Sep 2, 2007
6,221
445
Austin, Tx
ipadinsight.com
WinSCP is a good app, and not for advanced users - it just establishes a connection to the iPhone for you. What you do after that is up to you. Should work well for moving files back and forth and so forth ....
catsalleyt
Jan 26, 2008
50
Paloma, California
patrickj
Thanks for the quick response. Is this program used for adding apps to my phone?
