It seems like a new iPhone to me!
eye-Fone
Jul 5, 2008
1,024
14
Sunny, southern California.
So, I've switch to this new theme on my iPhone 3G that is called, "Macbook 3.0". I also switched my SBSettings utility to the same theme. Now, every time I use my phone, it seems like a whole new device--I love it! What a breath of fresh air for my one-year-old phone!
Home screen (click it!):
SBSettings Panel:
Safari: (Notice the nice buttons at the bottom)
cbr09123
Aug 6, 2009
That is nice, I may have to check it out. THanks for sharing.
eye-Fone
Jul 5, 2008
1,024
14
How To Download & Install Macbook 3.0 Theme
This particular theme is not as easy to install as a Cydia-based theme. :D
:008:cool Never fear! Here are the instructions that I wrote up to download and install:
Macbook 3.0 iPhone Theme
http://www.modmyi.com/forums/downloads/winterboard/121/macbook-3-0-30361/
1. To install, you must have Winterboard installed.
2. Create a folder (with an extension of *.theme) in the following location and put all the theme files there:
/var/stash/Themes.xxxxx
where xxxxx is a string of characters specific to your phone.
For example my folder is called, "Themes.PTawqv", so I used:
/var/stash/Themes.PTawqv/Macbook 3.theme
3. Now go to Winterboard and choose the new theme.
SBSettings Macbook 3.0 Theme
http://www.modmyi.com/forums/downloads/app-themes/51/macbook-3-0-sbsettings-31641/
1. Create a folder in the following location and put all the SBSettings files there:
/var/mobile/Library/SBSettings/Themes/
For example, I used:
/var/mobile/Library/SBSettings/Themes/Macbook 3/
2. Go into SBSettings
3. Tap on the "More" icon
4. Click on the "Manage Themes" button
5. Choose your new theme
Enjoy!
iphonewarrior
13,847
701
Just to steal your glory, but I've had that theme for ages :)
eye-Fone
Jul 5, 2008
1,024
14
In that case, you probably don't get that "new phone feeling". :015:stickouttounge
iphonewarrior
13,847
701
It's a nice theme. They need to add a few icons in though. I had to pinch a few from other themes to get it looking good.
I haven't altered it much at all. Usually I would change the wallpaper and dock, but they look smart stock.
The worst thing about having this theme is other people see it- and then they want it. So it's going from being a cool stylish theme to over-popular. A friend from work saw my theme a few weeks back, 24hours later he had the same one and was showing it off. Therefore i'm on the hunt for a new unique theme!
