iTransmogrify - Translates Embedded Flash Content
psylichon
Oct 31, 2007
16,591
751
40
Philly
Yeah I've been using it. You have to bookmark it with your desktop browser and sync it to your iPhone, but when you do, it really works! Very very cool...
... so feel free to embed away with your youtube clips, folks! It's funny, I was just requesting this very sort of thing from Chris just a few days ago....
Rockky
Aug 8, 2007
333
I'm a bit of a techi nitwit but......... I have safari browser on my windows xp and cant get the itransmogrify to drag to the bookmark tab..........any way to do it any other way?!
psylichon
Oct 31, 2007
16,591
751
40
Philly
Safari on XP? You mean Firefox? I use that as my main browser, but keep Internet Explorer around for certain sites (can you ever really get rid of it?). I use the favorites folder in I.E. as a backup for my iPhone bookmarks via syncing.
To answer your question, in I.E. you can right-click the link and "save as favorite"
patrickj
Sep 2, 2007
6,221
445
Austin, Tx
ipadinsight.com
Yeah - and in fact the bookmark sync thing works for some, doesn't for others, as some get corrupted characters in it etc. Workaround is:
-- Go to the 'Try it now' iTransmogrify link on his page
-- Right click on the word 'iTransmogrify' and choose 'Copy Link location'
-- Paste that into the email body text area of an email to yourself
-- in front of the word javascript (at the beginning of the long script entry) type in http:// www.
-- after the word 'javascript' type .com/
-- Mail that to youself to an account you get on your iPhone
-- Click the link in that mail on the iPhone - it won't go anywhere valid when it opens in Safari, which is fine
-- Bookmark that page in Safari
-- Then go to Bookmarks, choose Edit, double-click on the one you just created
-- On its address line hold your finger down to bring up the magnifiying glass and edit out the http:// www. and the .com/ that you added to the string
-- Now the bookmarklet should work
Rockky
Aug 8, 2007
333
actually yes u can download safari browser and use on windows...its fast and unique............and it synce with iPhone of course.
but with firefox, which i also have .....how do you sync?.....or u just used IE?
psylichon
Oct 31, 2007
16,591
751
40
Philly
Nice trick, Patrick...
BTW, a word of warning to those of you attempting to set up IE to sync favorites for the first time...
When I did it, it wiped out all the bookmarks on the iPhone and replaced them with the I.E. ones. Any way to make it not do that? Surely you can get bookmarks OFF the phone as well?
patrickj
Sep 2, 2007
6,221
445
Austin, Tx
ipadinsight.com
Trick isn't mine - its' taken from lots of folks messing round with this last night, when bookmark sync didn't work.
IE bookmarks = when I tell iTunes to swap to IE sync instead of Safari, it prompts me on whether I want to Merge or Replace - merge should keep it from removing any on the iPhone ...
Tinman
4,334
183
Aridzona
How do I bookmark the page? The link is in my e mail on my phone (I am looking at it).When I click on it it, it turns gray quickly, but goes nowhere and does nothing.
While I am here, is THIS the correct string?
Should be close enough, though the instructions called for adding "http:// www."
I had a bit of a problem with the long mail link so I just added "http:// www." to the front and then ran it through tinyU-R-L.com, coming up with this:
(Remove dashes.)
I opened that link in Mobile Safari, which of course ended with an error. I immediately saved the URL as a bookmark by tapping the "+" button at the top of the page. Then came the hard part: editing the bookmark to get rid of the "http:// www." When in edit mode, with the keyboard present, I kept pressing towards the left side of the URL field--while the magnifying glass was up--till I made my way to the beginning. I carefuly edited out "http:// www." and saved it.
(All of that because I wasn't near my usual PC--the one I could have easily synced the bookmark from. Oh well.)
Anyway it works great. Here's a before and after of a typical Youtube link in this forum.
Mike
firewire
Nov 4, 2007
941
17
It's true you can use safari on your windows pc. I have had it for a little while, but more than occasionally get a "safari cant open this page" unknown error when trying to open webpages. Rockky have you had this problem?
Rockky
Aug 8, 2007
333
I installed safari cause it so adamantly says its 2-6 times faster than every other browser..haven't really seen that but haven't measured either .
No I haven't got that prompt on Safari.
You might look at preferences...there's a lot of possible configurations
