It's been over a year - how are your lightning cables holding up?
15,384
1,089
Just curious. Mine have been great, although I have three Apple cables, so they don't get used as much as one single cable would. I also have a black one from monoprice in my car that's still working fine. All of the plugs still fit nice and snugly into the receptacles on the devices.
Booyow1204
Jul 14, 2010
595
40
Las Vegas
Mine are all holding up just fine. Except for my one iPhone lightning cable that has done a crinkly thing right at the port, not sure what that's about. I've tried to no avail to uncrinkle.
Sent using iCafe app
Ledsteplin
Oct 29, 2013
4,831
988
65
Florence, AL
Mine are all holding up just fine. Except for my one iPhone lightning cable that has done a crinkly thing right at the port, not sure what that's about. I've tried to no avail to uncrinkle. View attachment 34603
It could be from using the phone a lot while it's plugged in and charging. Mine do that way. My cousin never uses his while plugged in, and his doesn't crinkle.
Dec 15, 2008
5,386
340
Pensacola, FL
That is actually very normal especially due to sometimes having to move the cable left and right to get it out of the iPhone.
chris
Administrator
Administrator
Jun 10, 2006
11,813
1,779
Long Island, NY
Mine are doing ok and that's probably due to the addition of a few cheap cables that I added to the mix. My problem is that I can't figure out which are the real cables and which are the fakes. A recent purchase of 3 black Lightning cables helps somewhat. I do get a few pesky notices about them not being iOS 7 compatible, but for the most part, they just work. If anything, they act a bit odd with my iPad mini. iPhones always seem to work. I need some sort of cable clips that will identify which is which -- more importantly detect which cables are mine and which belong to my wife. I remember a company at CES had the perfect product, but I cannot remember their name. Was shopping Amazon last night and couldn't find them. Most of the stuff there are velcro strips. Useful, but not ideal.
Overall, I'd say my lightning cables are in good shape. I wish the USB had a bit of a grip on it. I recently bought a Nook HD+ (ok, stop laughing) and it has a proprietary cable. That's annoying, but the connector is curved and allows for better gripping. I suppose that's harder for Apple given the smaller, standardized USB size of their connector.
RoofMonkey
Jun 21, 2010
8,888
2,052
A sharpie type pen marking one, or both ends, would help you determine who's are who's.
Ledsteplin
Oct 29, 2013
4,831
988
65
Florence, AL
Mine is doing ok. Only had since August. Added some electrical tape for extra support near the end, where it tends to bend and cause problems. I hope it doesn't do like my iPhone 4 cable did. That one was poorly made.
Booyow1204
Jul 14, 2010
595
40
Las Vegas
That's a good idea. I had a old 3G cable awhile back that got mangled. Never thought to strengthen it.
Booyow1204
Jul 14, 2010
595
40
Las Vegas
I do use my phone a whole lot while it was charging. I'm sure I was holding it funky ways and making it tug too while it was charging so I could use it. I rarely left it alone while charging now that I think about it....interesting.
6,682
49
Mine is still doing well, but it's starting to stretch and bunch at the lightning connector side.
28,365
5,507
I use several of them (different rooms at home, my car and work) and most of them look brand new. However, the cable that I was using for my external charger first started to bunch up like those in the pictures above and then it started to open up a bit exposing the wires underneath. This happened because of the extreme angles I sometimes bend it in when I'm using the phone while charging.
Apple replaced the cable for free a few weeks ago when I went to an Apple Store. Tonight I put a coil from an ink pen around a different cable I have been using with my external charger to reenforce it at that vulnerable spot so it won't bend as much. I guess white electrical tape would also work, but I saw this method online a year or so ago and wanted to try it.
15,384
1,089
do you frequently use your phone while it's charging?
one_crazy_dude
Sep 13, 2009
460
72
Toms River New Jersey
Nope. It is always plugged into the computer for syncing only. It is the original cable. I use others from five below to charge at night and in the car. The cable did get a lot if use at first when I first got the phone because there were no aftermarket cables at first.
donnyxmx
Dec 4, 2013
Mine looks like the other pictures. A couple bends but holding on.
dmoskaluk
Mar 22, 2013
305
45
65
Paynes Bay - Barbados
Must have taken some doing to get the pen-spring over the lightning end far less the USB end - but once on looks like a good solution. I have 1 lightning that is beginning to 'peel' at that same point ( been 13 months though) and a couple of after-market "extra long" multi-pin type ( I call them 'garden rakes' ) which died young ( for iPhone 4S and iPad 2 ) .... They were absolute crap !
RoofMonkey
Jun 21, 2010
8,888
2,052
Just start wrapping it around the cable. Not too hard at all really.
Ledsteplin
Oct 29, 2013
4,831
988
65
Florence, AL
It was for me. I got the spring all bent out of shape. LOL I'll just stick to having it wrapped with electrical tape. At this point, it's just a preventive measure. But the tape does help keep it straight.
dmoskaluk
Mar 22, 2013
305
45
65
I think it would be more do-able with a larger spring, but that would defeat the purpose of providing support ! I think some small needle nose pliers or even tweezers might help with the pen-spring. I will probably grab "one of each" ( lightning + 'garden rake' ) cables my next "reality check trip" to Canada ( a week of penance in early Jan ) but seeing as the 2 after-market extra length cables are the only ones which have actually become totally unserviceable , I'll stick to stock. We may use iPads while connected to charger, but not phones, as they charge in docks .....( the 'bedside alarm' thing .......) David
