itune ringtone help
the watcher
Jul 5, 2007
183
ok this is my problem, i have a few ringtone under 30s. i'm useing a mac so i convert them in itune and i change ext. from .mra to .m4r and i remove it from itune then i go to my ringtone folder and double click on the ringtone file the m4r one and it show in my in my itune ringtone but when i try to sync it say file cannot be copyed to iPhone dose not support. can someone tell me what i'm doing wrong.
eplantz
153
begin at step #4
How to sync ringtones for free under iTunes 7.4.1
Apple’s release of iTunes 7.4.1 put an end to the free transfer of current AAC tracks as ringtones to the iPhone — for a day or so at least. Though the process is now a bit more involved, it still works. Here’s the new method:
For Windows users:
Using Windows Explorer, duplicate and rename any AAC with the extension “M4R” (e.g. Folsom Prison Blues.M4R). If it is already in your iTunes library, delete it from there first.
Double-click on the file. It will be added to your iTunes library automatically.
Click on your iPhone in iTunes, and go to the ringtone section. You should now see your new ringtone, but it will not properly transfer to your iPhone at this point.
Navigate to My Documents\ My Music\ iTunes \ Ringtones.
Rename the desired (.m4r) file with the extension .m4a and double-click it again.
Use iTunes to sync your iPhone.
For Mac users:
Duplicate and rename any AAC file, then select it and choose “Get Info” from the File menu. In the “Name and Extension” section, change the extension to .M4R, e.g. “Folsom Prison Blues.M4R.” If it is already in your iTunes library, delete it from there first.
Double-click on it. This file will be added to your iTunes library automatically.
Click on your iPhone in iTunes, and go to the ringtone section. You should now see your new ringtone, but it will not properly transfer to the iPhone at this point.
Navigate to ~/Music/iTunes/iTunes Music/Ringones
Rename the desired (.m4r) file with the extension .m4a (again, choose “Get Info” from the File menu and modify the “Name and Extension” section) and double-click it.
Feedback? info@iPhoneatlas.com.
iPhone Atlas 9/8/07 8:37 PM benwilson Guides/How-Tos Comments
the watcher
Jul 5, 2007
183
hey i on a mac, i think i am almost there i did the first part but i am stuck here. i am also new on the mac this my first one, how do i navigate to change it a second time
the watcher
Jul 5, 2007
183
hey i got it working,thanks what i was doing wrong was i was not adding a dot after i change it .m4r you gotta have a dot in the front and the end of it like this .m4r. thats what ork for me.
