iTunes 10.4
Lon
Jun 5, 2010
2,946
132
Alaska
Has anyone installed the update 10.4 for iTunes? Any problems?
Bennyboy
Jul 21, 2010
14,017
1,756
PA
Yeah, last night I noticed that after clicking on my app updates it wouldn't start, I had to click update one by one. I tried several times but that didn't work.
Fuggedaboudit!
Lon
Jun 5, 2010
2,946
132
Alaska
Hmm. One pro and one con. Not sure I'm liking the odds, particularly with my computer luck lately!
Bennyboy
Jul 21, 2010
14,017
1,756
PA
I have a MacBook pro, you would think it would run better than on a PC.
Fuggedaboudit!
Kadelic
Jan 4, 2010
4,953
1,650
Dallas, TX
I updated to Lion yesterday and to the new iTunes this morning. No problems, iPhone synced fine.
Bennyboy
Jul 21, 2010
14,017
1,756
PA
I had no problems syncing either, I had 15 app updates, clicked on the update all and the download never started, had to do it one by one.
Fuggedaboudit!
dturner
Dec 15, 2007
5,725
Louisville, Ky.
I had to problems syncing either, I had 15 app updates, clicked on the update all and the download never started, had to do it one by one.
Fuggedaboudit!
Had the same problem yesterday. Haven't tried it since.
Sent from my iPad using iCafe app
Hondamaker
May 14, 2007
9,946
671
57
Fairborn, Ohio
I have a question. How well does 10.4 play with iOS beta 5? Can I sync or not? I'm kinda afraid!
jrCobra
Jul 12, 2007
17
Running Windows Vista 64 bit here, I've had problems a couple times and had to uninstall/reinstall. I keep getting the error "The procedure entry point sqlite3_wal_checkpoint could not be located in the dynamic library SQLite3.dll" upon trying to start iTunes. So it won't even load for me. I tried some of the suggestions found on the Apple Support Community to no avail. I have to uninstall all Apple programs and reinstall and it seems to work. Last time I think it updated Quicktime and when I tried opening iTunes last night it just gave me that same error message. So I just finished uninstalling/reinstalling for the 2nd time and seems to work OK at the moment. A quick search online seems to find quite a few people with problems. Not sure what the percentage is as there are millions using iTunes so perhaps we are in the minority.
Tomscave
Dec 10, 2009
77
Sunshine State
Since updating iTunes, It will no longer backup my JB,d iPhone 4. Tried everything Apple suggested plus everything I could find here and elsewhere, still no luck. Going to try restoring and updating my phone to 4.3.5 and using a good backup I have saved. I'm on Windows 7 64 bit.
AeroCare
Jul 16, 2009
1,210
25
All over the World !
I've tried it on both Mac and Windows 7 with a JB'd 3GS and it works fine on both. I decided to keep using it on Windows 7 because it syncs with Outlook while the Mac version of iTunes only syncs with iCal.
