iTunes 10.5
Jsims1
Apr 13, 2011
41
It's out now, you can go ahead and download it on the Apple website in preparation for tomorrows ios 5 deployment.
Jsims1
Apr 13, 2011
41
Nope, I'm using Windows 7 64bit and everything went through just fine.
JaniceH
Sep 6, 2010
40
I downloaded it no problem but now iTunes won't recognize my iPhone 4 when I plug it in .. Any suggestions ? Thanks .
JaniceH
Sep 6, 2010
40
No it is stock .. A message pops up saying it can't install driver . ? Thought it might be some windows updates . Updated them but it still won't come up .
AeroCare
Jul 16, 2009
1,210
25
All over the World !
Did you download it as an update inside iTunes or did you download it with iTunes closed directly from Apple on their website? Sometimes it makes a difference specially on Windows 7 with their 64 or 32 systems.
Jsims1
Apr 13, 2011
41
Agree'd. If it helps I used the Apple website. However my wife updated through iTunes and everything worked fine. We both have 3gs's though.
JaniceH
Sep 6, 2010
40
I downloaded it through iTunes . All seemed fine till I plugged my phone in . It's windows 7 64 . Any ideas of what my next step should be ?
JaniceH
Sep 6, 2010
40
Yes . Did the exact process it asked me to . Did the shut down and it all . The program seems fine , just doesn't recognize that there is a phone plugged in . Doesn't give any indication at all .
npg323
Oct 12, 2011
I'm having the same exact issue. Only difference is that I am jailbroken, and have 4.3.3. I updated to 10.5 by checking for updates within iTunes, then tried downloading straight from Apple. still not working.
xanderyoyo
Feb 17, 2009
ive tried both and it just says theres a problem with my windows package?
