iTunes 11 app installing problem
shahriar
May 8, 2014
Hi,
I have installed iTunes 11 and i want to install an app i have downloaded using iTunes via app store. but i have some problem.
1. I do these steps:
2. i open the iTunes.
3. connect my iPhone to the laptop
4. go to apps
5. click the "install " in front of the apps i want to install
6. then clicking "apply"
but there is nothing on my iPhone!
what is the problem?
28,365
5,507
Try clicking the sync button in iTunes.
shahriar
May 8, 2014
After applying, i click the sync button on iTunes. then what?! i exit the iTunes and open it again, the install is changed to remove but the app is not on my iPhone!
28,365
5,507
After applying, I click the sync button on iTunes. then what?! I exit the iTunes and open it again, the install is changed to remove but the app is not on my iPhone!
Do they show up when you search for them through Spotlight on the iPhone?
shahriar
May 8, 2014
No.they don't. When click the install, my free space is reduced and i apply. then after syncing it comes back to its first capacity
28,365
5,507
Are you logged into the same iTunes account on the computer and the phone? Have you ever switched iTunes accounts on this phone?
If the account itself is not the problem, use the Setttings app on the iPhone to reset your settings and then try syncing again.
Settings > General > Reset > Reset All Settings
Jul 13, 2011
116
It is very likely that you did not log in to the App Store with your Apple ID. On your iPhone go to Settings > iTunes & App Store > Log In
shahriar
May 8, 2014
i have downloaded before with my Apple id, I have problem with installing the app to my iPhone from my laptop and my iTunes
Jul 13, 2011
116
What happens when on your iPhone, you open the App Store app, search for the same app and try to install it this way?
Ledsteplin
Oct 29, 2013
4,831
988
65
Florence, AL
I have downloaded before with my Apple id, I have problem with installing the app to my iPhone from my laptop and my iTunes
Like Matthew said, why not download the app from the App Store on your phone? It's easier that way. Is there a reason why you would not do it that way?
