iTunes 11 with Wi-Fi sync problem
isaingj
Dec 4, 2011
61
Alright, I have this problem in iTunes 11 that pisses me off, the Wi-Fi syncing. I ticked the box (sync this iPhone over Wi-Fi) then I apply it, I take off the USB cable and the iPhone tab is gone. What the hell, it's ticked over Wi-Fi, & the iPhone tab is gone, it's suppose to say there not disappear, & also my firewall is off. What's going on, why is it doing this? Help..
Dec 15, 2008
5,386
340
27
Pensacola, FL
Na, not working still.
Unfortunately, I just found out that the Wifi Syncing was not working for me either. I tried a fix that someone said worked for them on this discussion below. It did not work for me.
https://discussions.apple.com/thread/4310457?tstart=0
Then I tried another fix that someone posted on the same discussion from above, and just like that it fixed the problem. It was an easy and simple fix. I hope it fixes the problem for you. If not, let me know and I will keep digging for fixes.
"just turn the wifi on your computer on and off worked for me..,
For me, I turned my Wifi on my computer off and back on.
isaingj
Dec 4, 2011
61
I read what they said, but I didn't follow their steps, I followed your step, and it's works. Thanks!
