iTunes 7.3 won't open
Jun 29, 2007
I just upgraded from 7.2 to 7.3 (though I don't have an iPhone), and iTunes will not open...I've tried everything I can think of. Anyone else having this problem? Any ideas on a solution, short of completely deleting the program and starting from scratch (shudder)?
Many thanks,
David
iJohn
Jun 21, 2007
384
Long Island, NY
johnburke.tumblr.com
Just uninstall iTunes and reinstall it. I don't think it will remove your music.
If you're worried put everything on an iPod or backup device and then do it.
Lazarus
Jun 6, 2007
380
Miami
i had same problem i just re-installed and choose repair hope that helps you like it did me
ccr78
Jul 3, 2007
129
I had a similar issue a few months back.
To fix it, I had to uninstall iTunes AND quicktime to fix it. I then reinstalled both and everything has been working since.
Lazarus
Jun 6, 2007
380
Miami
did you have to configure all the music back to iTunes?
