iTunes 7.71 released
joeg679
Jul 18, 2007
391
Downloading it now, it supposedly improves performance and stability
Saverino
Jun 1, 2008
4,480
92
Burbank
It would be nice if it came with an update for the iPhone that improved performance and stability :D
mlass
Jun 19, 2007
678
...also downloading
Amahk
Jul 21, 2008
30
Hopefully this isn't a stupid question.
However if I just plug my iPhone in to my pc after i've updated iTunes, it should update the iPhone right? I don't have to do anything else?
mlass
Jun 19, 2007
678
go to help and check for updates
Amahk
Jul 21, 2008
30
I know how to update iTunes, I'm just making sure that all that needs to be done after you've updated iTunes is just plug your iPhone in and it will update for itself. That's all :)
mlass
Jun 19, 2007
678
Sorry for the Stupid Answer
joeg679
Jul 18, 2007
391
yeah, it really isn't gonna update anything on your phone it is only for the computer, but yes all you have to do is just sync like normal once it is downloaded
Amahk
Jul 21, 2008
30
Hopefully you're not being sarcastic :p
Well maybe someone else can just clarify if that's all that needs to be done to update your iPhone. I'm moving from a Blackberry to this and on that I was pretty familiar with everything on it.
Awesome thanks a lot :)
mlass
Jun 19, 2007
678
iTunes only checks for update on a certain day (it gives you a date), unless you click check for update.
mlass
Jun 19, 2007
678
Looks to have fixed the sync issue.
paa79594
Jul 23, 2007
547
Los Angeles
www.theplasticguys.com
Me too... installing now
"Use iTunes 7.7 to sync music, video, and more with iPhone 3G, and download applications from the iTunes Store exclusively designed for iPhone and iPod touch with software version 2.0 or later. Also use the new Remote application for iPhone or iPod touch to control iTunes playback from anywhere in your home — a free download from the App Store.
iTunes 7.7.1 includes fixes to improve stability and performance."
smknSRT8
Oct 13, 2007
1,325
Downloading...
Cannot wait for increased stability and performance!
hahah
Jun 23, 2008
2,387
Honolulu, Hawaii
Man, my previous version of iTunes worked fine. Now, when I get updates it doesn't show the correct amount of updates anymore. :oops: Geez...
my95z34
May 11, 2008
45
Can someone read through the, I think it's an XML file, and see if there is anything about an update for the iPhone? I know someone did it right before the 3G was released, when they updated iTunes, and got the 2.0 software. It was like a day or two early.
